Using JavaScript to Configure a Toolbar
You can configure a JavaScript toolbar or create a new JavaScript toolbar.
Note: To use scripts, go to Siebel Tools
To use JavaScript to configure a toolbar
  1. Create a JavaScript file.
    You use this file to define a custom JavaScript toolbar class that is a subclass of JSSToolbar.
  2. Copy the JavaScript file to the following directory on the Siebel Application Interface:
    SIEBEL_AI_ROOT/applicationcontainer_external/siebelwebroot/scripts
  3. In Siebel Tools, display the DLL object type and the Class object type.
    For more information, see Displaying Object Types You Use to Configure Siebel CRM.
  4. Create a DLL object:
    1. In the Object Explorer, click DLL.
    2. In the DLLs list, add a new record using values from the following table.
      Property Value
      Name
      Enter a name for the DLL object. For example, BarcodeToolbar.
      Project
      Choose a project that is currently locked in the Siebel Repository.
      File Name
      Enter the file name that references the JavaScript file. For example, barcodeToolbar.js.
  5. Create a Class object:
    1. In the Object Explorer, click Class.
    2. In the Classes list, add a new record using values from the following table.
      Property Value
      Name
      Enter the name of the class that is defined in the JavaScript file. For example, JSSBarcodeToolbar.
      Project
      Choose the project that you defined in Step 3.
      DLL
      Choose the name of the DLL object that you defined in Step 3.
      High Interactivity Enabled
      1
  6. If you create a new toolbar, then create a Toolbar object.
    Make sure you set the Class property to the class defined in the JavaScript file. For example, JSSBarcodeToolbar. For more information, see Creating a New Toolbar.
  7. Add new toolbar items.
    For more information, see Adding a New Toolbar Icon to a Predefined Toolbar.
  8. If you create a new toolbar, then add a <div od-type="toolbar"> tag to the appropriate web template.
    Make sure you set the name property that you define in the <div od-type="toolbar"> tag to the name of the Toolbar object that you created in Step 6. For more information, see Using Web Templates to Configure Toolbars.
  9. Add <div od-type="toolbaritem"> tags to the <div od-type="toolbar"> tag.
