Configuring an XML Hierarchy Converter (Incoming)
The first connector component in the inbound sequence is a hierarchy converter. For information about Siebel hierarchy converters, see XML Reference: Siebel Enterprise Application Integration.
To configure an XML hierarchy converter
  1. Name the hierarchy converter appropriately (it must be unique within the workflow).
  2. Choose the type of business service from the multi-value group (MVG) window.
    For this component, choose the XML Hierarchy Converter.
  3. Choose the method.
    This example uses the XML Document to XML Hierarchy method because, for an incoming message, the conversion is from an XML document to an XML hierarchy that can be used by the FINS ACORD XML Dispatcher.
  4. Set the input and output arguments, XML Hierarchy name, and XML document name.
    The following are the input argument settings for the example hierarchy converter incoming configuration.
    Input Argument Type Value Property Name Property Data Type
    XML Document
    Process Property
    <Value>
    String
    The following are the output argument settings for the example hierarchy converter incoming configuration.
    Property Name Type Value Output Argument
    PropSet XML Converter Out (Incoming)
    Output Argument
    XML Hierarchy
