Configuring the FINS ACORD XML Data Transformation Engine
The second component is the data transformation engine (DTE).
To configure the DTE
Name the DTE appropriately (it must be unique within the workflow).
Choose the type of business service from the multi-value group (MVG) window.
For this component, choose the FINS ACORD XML DTE.
Choose the method.
The example uses the Transform to External Hierarchy method because the data is moving from a Siebel internal system to an external system.
Set the input and output arguments.
These arguments include the DTE map name, created during the configuration of the internal and external integration objects.
The following are the input argument settings for the example DTE configuration.
Input Arguments Type Value Property Name Property Data Type XML Property Set
Process Property
PropSet TransMgr Out
Hierarchy
The following are the output argument settings for the example DTE configuration.
Property Name Type Value Output Argument PropSet DTE Out
Output Argument
XML Property Set
