Configuring the FINS ACORD XML Data Transformation Engine (Incoming)
The fourth connector component is the data transformation engine (DTE).
To configure the DTE
  1. Name the DTE appropriately (it must be unique within the workflow).
  2. Choose the type of business service from the multi-value group (MVG) window.
    For this component, choose the FINS ACORD XML DTE.
  3. Choose the method.
    The example uses the Transform to Siebel Hierarchy method because the data is moving from an external system to a Siebel internal system.
  4. Set the input and output arguments.
    The following are the input argument settings for the example DTE incoming configuration.
    Input Argument Type Value Property Name Property Data Type
    XML Property Set
    Process Property
    PropSet Converter Out (Incoming)
    Hierarchy
    The following are the output argument settings for the example DTE incoming configuration.
    Property Name Type Value Output Argument
    PropSet DTE Out (Incoming)
    Output Argument
    XML Property Set
