Configuring the FINS ACORD XML Data Transformation Engine (Outgoing)
The sixth connector component is the data transformation engine (DTE).
To configure the DTE
Name the DTE appropriately (it must be unique within the workflow).
Choose the type of business service from the multi-value group (MVG) window.
For this component, choose the FINS ACORD XML DTE.
Choose the method.
The example uses the Transform to External Hierarchy method because the data is moving from the Siebel internal system to an external system.
Set the input and output arguments.
The following are the input argument settings for the example DTE outgoing configuration.
Input Argument Type Value Property Name Property Data Type XML Property Set
Process Property
PropSet TransMgr Out (Outgoing)
Hierarchy
The following are the output argument settings for the example DTE outgoing configuration.
Property Name Type Value Output Argument PropSet DTE Out (Outgoing)
Output Argument
XML Property Set
