Configuring Application Settings for Siebel Mobile
The Administration - Siebel Mobile, Application Administration view lists all the mobile applications that are available within your enterprise. From the Application Administration view, you can create new application settings, change default settings, and administer settings that have already been created. Some of the settings are described in Siebel Mobile Application Settings.
The following tabs, which are available from the Application Administration view, are used by the synchronization engine to extract application definition and user data:
Business Component Filters. Use this tab to define the synchronization filter settings for business components. For more information, see Adding Business Component Filters for Siebel Mobile Users.
Business Object Filters. Use this tab to define the business object level filters, which restrict data that is downloaded to the mobile client application upon synchronization. For more information, see Adding Business Object Filters for Siebel CRM Users.
Settings. Use this tab to define parameter settings for your application. For more information, see the following:
