Starting and Ending a Shift
Complete the following procedure to start and end a shift.
To start and end a shift
- Tap Side Menu and then tap Shifts to display the following: - The Shift list in the main pane.
- The Calendar showing the activity planning information in the side pane.
- Tap a shift record in the main pane.
- Tap Start when you start the shift to record your start time and date.
- Tap Complete when you end the shift to record your end time.
