Submitting a Call for Processing
After you complete all of the information for the call, and after you capture the signature for the disbursed samples, you submit the call for processing. You can submit only calls that have a Status field of Planned or Signed. At least one disbursed sample must be associated with a call before you can submit it.
You submit a call for processing to close the call. After you submit a call, you can review but not update the call. The inventory of the sales representative is decreased by the disbursed samples and disbursed promotional items for the call.
To submit a call for processing
- Tap Side Menu and then tap Calls to display the following: - The calendar showing the call planning information in the main pane.
- The Contacts and Accounts list in the side pane.
- Tap a call on the calendar in the main pane to open it and display the following: - The details for the selected call in the main pane.
- A list in the side pane in which you can select the related items for the call.
- Tap Submit to submit the call for processing. - The Status field for the call changes to Submitted. You cannot resubmit a call with a Status field value of Submitted. The call is now closed and locked.
