Connect String and Credentials for the SiebelDataBean
When using the SiebelDataBean directly, without any generated code, three arguments must be passed to the login method. A fourth argument, language code, is optional.
connect string
Siebel username
Siebel password
language code (default is enu)
The connect string has the following form:
siebel://SiebelServerName:SCBPort/EnterpriseName/XXXObjMgr_lang
For example:
siebel://examplecomputer:2321/mysiebelenterprise/SCCObjMgr_enu
When using generated code, these parameters can be taken from the siebel.properties file, which must be in the classpath of the Java Virtual Machine (JVM). These properties are read from siebel.properties at the time an instance of the generated business service class is created using that explicitly specifies siebel.properties, for example:
Siebel_AccountBusServAdapter svc = new
Siebel_AccountBusServAdapter("siebel.properties");
They can be overridden by calling the methods setConnectString, setUserName, setPassword, and setLanguage any time prior to calling initialize() or invoking a business service method (such as GenericMethod in Methods for Java class com.siebel.service.jdb.GenericServiceBusServAdapter). This is the behavior when the default (no-argument) constructor of the generated Java class is used.
Alternatively, the generated class provides the following four constructors with arguments:
One String argument: the name of the property file to be used.
Three String arguments: the connect string, username, and password. No properties file is used.
Four String arguments: the connect string, username, password, and language. No properties file is used.
SiebelDataBean argument: the SiebelDataBean passed already has parameters assigned and its login method executed.
