Scenario 2: Process of Outbound Integration Using External XML and an XSD or DTD
This topic gives one example of how to set up an integration based on incoming XLML that has been defined in an XSD or a DTD. You might use this integration differently, depending on your business model.
To set up the outbound integration, perform the following tasks:
