Required Initial Values for File Attachment Columns
Each file attachment row must contain the filename reference to the files you want to import and the appropriate values in the following columns:
FILE_NAME. Set this column to the root filename of the file attachment.
FILE_EXT. Set this column to the extension type of the file attachment (such as DOC, XLS, or TXT).
FILE_SRC_TYPE. This column must be set to FILE.
For more information on file attachment columns, see File Attachment Columns.
