USING SYNONYMS Parameter for Optimizing EIM
Ignore account synonyms. Set the USING SYNONYMS parameter to FALSE in the .IFB file to indicate that account synonyms can be ignored during processing. This logical operator indicates to EIM that account synonyms do not require processing during import, thus reducing the amount of processing. Do not set the USING SYNONYMS parameter to FALSE if you plan to use multiple addresses for accounts. Otherwise, EIM will not attach addresses to the appropriate accounts. You can use EIM_ACCOUNT to import accounts with multiple addresses and then specify the primary address for an account by setting ACC_PR_ADDR to Y.
