Using Trace Flags, SQL Trace Flags, and Error Flags
You can activate trace flags and error flags to log transactions. This topic covers the following types of flags:
Error flags. See Error Flags.
SQL Trace flags. See SQL Trace Flags.
Trace flags. See Trace Flags.
Recommended settings for error flags, SQL trace flags, and trace flags include the following:
To display errors and unused foreign keys. Start with the following setting combination. The setting Trace Flag=1 provides a summary (after each batch) of the elapsed time in EIM steps 10 and 11.
Setting |
Value |
Error Flag |
1 |
SQL Trace Flag |
1 |
Trace Flag |
1 |
To determine SQL performance. The following setting combination produces a log file with SQL statements including the elapsed time for each statement.
Setting |
Value |
Error Flag |
1 |
SQL Trace Flag |
8 |
Trace Flag |
3 |
To determine optimal batch size and monitor performance in a particular step. The following setting combination produces a log file showing the elapsed time for each EIM step.
Setting |
Value |
Error Flag |
0 |
SQL Trace Flag |
0 |
Trace Flag |
1 |
