Component Parameters for the Fulfillment and Part Locator Engines
Component parameters for the engines in Siebel Field Service determine the behavior of each engine. Changing the values of these component parameters changes the default behavior of the engine. To implement changes to component parameters, restart the Field Service server. For more information about changing the values of component parameters, see Siebel System Administration Guide.
The following table describes these component parameters for the Fulfillment Engine and Part Locator Engine.
Component Parameter | Default Value | Description |
SysPref_DefaultFulfillInvLoc |
SFO |
Specifies the default inventory location to use as a source inventory location. The engines use this default value as the source inventory location if the user does not specify the source inventory location at run time. The value must be the row ID of the service inventory location. To see this ID, select an inventory location in any Service Inventory view, and then select About Record from the Help menu. |
SysPref_OrderItemStatusToBeFulfilled |
Open, New, Pending |
Specifies the valid values for the order item status. The values come from the Order Item Status LOV, and the individual values are LIVs. |
SysPref_OrderStatusToBeFulfilled |
Specifies the valid values for the order status. The values come from the Order Status LOV, and individual values are any of the LIVs. |
SysPref_OrderTypeToBeFulfilled |
Service Order, Internal Order, RMA Advance Exchange |
Specifies the valid values for the order type. The values come from the Order Type LOV, and individual values are any of the LIVs. |
SysPref_Fulfill-SearchAllSublevels |
TRUE |
Specifies whether child locations are searched. Values include:
SysPref_InventoryTypeForPT |
Warehouse |
Specifies the inventory location type for generating pick tickets. The values come from the Inventory Location Type LOV, and individual values are any of the LIVs. |
SysPref_AllocationRule |
1 |
Specifies the rules for substitution. Values include:
