Configuring Tracing for the Cycle Counting Engine
Depending on the type and quantity of information you want to collect, you can set different tracing levels for the Cycle Counting Engine.
This task is a step in Process of Administering Cycle Counting.
To configure tracing for the Cycle Counting Engine
Navigate to the Administration - Server Configuration screen, then the Servers view.
Click the Parameters view tab.
In the Server Parameters list, locate the Trace Flags parameter.
Set the appropriate values for the fields in the Trace Flags parameter record.
