Defining Constraint Sets
Constraint sets provide the basic definition for a predefined set of constraints that a service region uses for running the Optimizer. You associate a constraint with a service region in the Service Region List view of the Administration - Scheduling screen. For more information, see Creating Service Regions.
To define a constraint set
  1. Navigate to the Administration - Scheduling screen, then the Constraint Sets view.
  2. Create a new constraint set record, and complete the field as appropriate.
  3. Scroll down to the Constraints list.
  4. Create a new constraint record, and select a predefined constraint from the Add Constraint dialog box that appears.
  5. Enter a start and end date for the constraint, if applicable.
  6. To view the service regions that are associated with the constraint set, click the Service Regions tab.
