Measurements and Readings
You define measurements for products in the Measurements view in the Service Information view in the Products view of the Administration - Product screen. For more information, see Setting Up Use Plans.
The Measurements view of the Assets screen associates measurements from a product with the selected asset. The view allows users to customize the measurements for an asset. For example, a relevant measurement for a copy machine is the number of copies, read from a counter. A relevant measurement for a car is the distance traveled, read from an odometer. A relevant measure for a pump is the oil level, oil, pressure, or temperature, read from gauges. For more information, see Associating Measurement Types with Assets (End User).
The Readings view of the Assets screen allows you to record the readings for specific measurements and specific assets. These readings can act as Usage and Threshold triggers.
