Process Flow for Receiving
When you receive a product, a receipt is generated as proof that the product arrived. The following figure shows the process flow for receiving.
Process Flow for Receiving. This image is described in surrounding text.
The process flow for receiving includes the following steps:
  1. If the order is unidentified, then generate an unknown receipt.
  2. If the order is identified (Internal Order, Purchase Order, Repair Order, or Return Material Authorization), then create a receipt.
  3. Generate the transactions.
    The necessary inventory transactions are created, and the necessary line item actions on received orders are created.
