Setting Component Job Parameters for the Fulfillment and Part Locator Engines
Follow the procedure in this topic to set the component job parameters for the Fulfillment and Part Locator Engines. For more information about server components and component parameters, see Siebel System Administration Guide.
This task is a step in Process of Administering Fulfillment.
To set the component job parameters for the Fulfillment and Part Locator Engine
Navigate to the Administration - Server Management screen, Jobs, then the Job Detail view.
Create or edit a component job for one of the following server components:
Service Order Fulfillment Engine (alias FSFulfill)
Service Order Part Locator Engine (alias FSLocate)
Add or modify the server component parameters, as needed.
For information about the applicable parameters, see the previous table.
