Setting Up Lists of Values
You can set up Lists of Values (LOVs), including LOVs for Siebel Quality, for use in Siebel Business Applications. For more information about setting up LOVs, see Siebel Applications Administration Guide.
The following table lists the LOVs to set up before using Siebel Quality.
Field Type Value for LOV Items Description Example LOV Items
Area
PROD_DEFECT_AREA
The functional product area.
Accounts
Orders
Browser
PSTASK_CLIENT_BROWSER
The type of Web browser running in the test environment.
IE 5.5
NS 6.2
Client OS
PSTASK_CLIENT_OS
The type of operating system running on the client.
Win 2000
Mac OS
Database
PSTASK_CLIENT_DB
The type of database running in the test environment.
IBM DB2
MS SQL Svr 7.0
Priority
PROD_DEFECT_PRIORITY
The relative importance of the issue.
P1. Critical
P3. Medium
Server OS
PSTASK_SERVER_OS
The type of operating system running on the server.
HP-UX 11i
Solaris 8
Severity
PROD_DEFECT_SEVERITY
The severity of the issue.
3. Wrong Behavior
4. Minor Error
Special Tag
PD_SPEC_TAG
The statuses or actions that other fields do not identify. Use for reporting, querying, exporting, or localization purposes.
BETA3
HIGH RISK
Status
PROD_DEFECT_SUB_STATUS
The implementation or development stage.
Open-Disagree
Closed-Verified
Subarea
PROD_DEFECT_SUB_AREA
The functional product area subdivision.
Expenses
Fulfillment
Substatus
The implementation or development substage.
Unassigned
Approved
Type
PROD_DEFECT_TYPE
The type or classification for the change request.
Product Defect
Enhancement
Siebel Application Interface
PSTASK_SERVER_OS
The type of operating system running on the Siebel Application Interface.
AIX 4.3.3
Win NT 4.0
This task is a step in Process of Administering Siebel Quality.
