Setting Up Lists of Values
The administrator typically sets up Lists of Values (LOVs) for use in Siebel Business Applications. Although all types of release items share the Status field, the LOVs for the Status field are likely specific to each release item.
For example, while the Status values for an engineering task typically relate to the development phase of the task (Unit Test, Final, and so on), the Status values for a technical publications document typically relate to the production phase of the document (Draft, Final Edit, and so on). So that users do not have to review long LOVs for phases that are related to their work, you might have to restrict the views where specific LOVs appear. For more information about setting up LOVs and restricting the views associated with specific LOVs, see Siebel Applications Administration Guide.
The following table describes the LOVs to set up before using Release Manager. In this table, the Type column denotes the drop-down list record in the List of Values view.
View Label Associated Release Items Type Description Typical Values
Client OS
QA Tests
PSTASK_CLIENT_OS
The type of operating system running on the client.
Windows 2000, Mac OS
Client Type
QA Tests
PSTASK_CLIENT_TYPE
The type of test computer used by the tester.
HTML
Database
QA Tests
PSTASK_CLIENT_DB
The type of database running in the test environment.
IBM DB2, Microsoft SQL Server 7.0
Effort
Engineering Tasks
PSTASK_ENGINEER_EFFORT
The amount of effort required of the engineer to complete the task.
High, Low, 1 Man Month
Priority
Features
PSTASK_PRIORITY
The relative importance of the feature.
High, Medium, P1. Critical
Revenue
Features
PSTASK_REVENUE
The amount of expected revenue if the feature is implemented.
High, Low, >5M, <1M
Risk
Engineering Tasks
PSTASK_ENGINEER_RISK
The amount of risk to destabilizing the product by undertaking the engineering task.
High, Low
Server OS
QA Tests
PSTASK_SERVER_OS
The type of operating system running on the server.
Windows NT
Source
Features
PSTASK_SOURCE
The source of the feature.
Customer Input, Market Survey
Status
All
PSTASK_STATUS
The current implementation or development phase of the release item.
Draft, Unit Test, Final
Test Class
QA Tests
PS_QA_TEST_STRATEGY_ TEST_CLASS
The sequence category of the test.
Certification Pass, Full Pass, Final Pass, Acceptance Pass, Browser Certification
Test Set
QA Tests
PS_QA_TEST_PLAN_TEST_ SET
The product area applicable to the test.
Install, Upgrade, Report, Charts, General
Type
QA Tests
PSTASK_ALT_TYPE
The type of test that is conducted.
Blitz, Ad Hoc, Detailed, White Glove
This task is a step in Process of Administering Release Manager.
