Setting Up Processing for Orders
You can set up processing for orders. The procedures in this topic make available from a predefined list the types of orders that appear in order-related views. After you add new types of orders and order actions, you must customize the processing that must occur when users select these new types and actions.
Caution: Do not delete types of orders or order actions
because the associated ROW_IDs provide values for other tables in
orders. To change or replace these entries, modify the List of Values
(LOV) for the entry, and then update (do not delete and re-add) the
entry.
This topic contains the following related information:
This task is a step in Process of Administering Fulfillment.
