Setting a Default Unit of Measurement
All participants must define a default unit of measurement (UoM) in each category of UoM that they use in their forecasts.
To set a default unit of measurement
  1. From the application-level menu, choose Tools, then User Preferences.
  2. On the link bar, click Unit of Measurement.
  3. Either create a new record and select the required category and unit of measurement, or change the unit of measurement in an existing record.
    The fields are described in the following table:
    Fields Description
    Category
    The category of unit of measurement. Select Length, Volume, or Weight.
    Unit of Measurement
    The preferred unit of measurement for the user (manager or sales representative).
