Adding Products to a Property
To add product records to a selected property, follow this procedure.
This task is a step in Process of Creating Property-Specific Products.
To add a product to a property
Navigate to the Property Administration screen, then the Properties view.
Identify the property to which to add a product, and drill down on the Name field of the property record.
Click the Event Order/Menu Items view tab.
In the Event Order/Menu Items list, add a new record and complete the necessary fields.
Some fields are described in the table that follows.
Field Comments Type
Picklist selections are as follows:
Event Order Item. Identifies a non-F&B-related product.
Menu Item. Identifies a F&B-related product.
Grouping
Identifies groups of related products. Allows you to associate this product with a product grouping. This enables users to construct searches for products on the groupings to which they belong.
Available values can vary according to the selection in the Type field. Product groupings are user-defined and are specific to the business requirements of your company.
For example, Ice Creams might be a grouping, helping users to find the ice creams that are stocked at a property.
Resource Type
Critical. The item is necessary for an event to occur. The application tries to reserve this item when a quote is created.
General. The item is noncritical; that is, not necessary for an event to occur.
Non Critical. The item is noncritical; that is, not necessary for an event to occur.
Revenue Sub Category
Revenue subcategory with which to associate this item.
Revenue Category
Read only. Populated from the selected Revenue Sub Category.
Parent Revenue Category
Substitutes
The products that can be substituted for the current product. Displayed selections are limited to those of the same Product Type as the current product. You can select multiple substitutes. This enables users to select substitute products from the list of those you specify.
Recommendation Message
A message that a user can use to influence a customer to buy the product. For example, if the product is an entree, you might specify a wine that is compatible with that entree.
Preventative Maintenance Plan
Allows you to associate a preventative maintenance plan with the product.
After being associated with a preventative maintenance plan in this view, the product becomes visible on the Administration - Preventive Maintenance screen, Products view. For more information about preventative maintenance plans, see the chapter on preventive maintenance in Siebel Field Service Guide.
Start Date
The first day when the product is available. Default value is the current date.
End Date
The last day when the product is available.
Generic Product
Allows you to associate a single generic product with the current property-specific product. Siebel Hospitality uses this information when generating a quote to map this specific product to the associated generic product specified in the opportunity.
Selections are limited to products of Type equal to Generic, and with valid start and end dates. The current product will replace the specified generic product in quotes.
(Optional) Click Check Description Spelling to check the spelling in the Description field.
When you save the record, Siebel Hospitality creates the product, releases it, and associates it with the default catalog category for the current property.
