CanInvokeMethod: ConfirmVoidEventCheck
Use this user property to enable the Void Event Check button for only event checks with a specified Status field.
Property | Description/Value |
Value |
[Status] = LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
Parent Object Type |
SHM Invoice Form Applet and SHM Invoice List Applet applets |
Usage |
Enables the Void Event Check button for only event checks with a Status field of Posted. |
