Configuring the Do Not Move Flag
When booking function spaces, users can specify that the function cannot be moved afterwards by other users (except administrators). For example, in the Quotes screen, Functions view, the Do Not Move Flag check box can be selected by users to restrict the movement of the function. For more information on using the Do Not Move Flag check box, see Preventing Functions from Being Moved.
The administrator can control the effects of users selecting the Do Not Move Flag check box by configuring the appropriate field in Siebel Tools. To configure the Do Not Move Flag check box, perform the steps in the following procedure.
This task is a step in Process of Setting Up Function Spaces.
  1. Log in to Siebel Tools as an administrator.
  2. Lock the TNT SHM Function project for editing.
  3. In the Object Explorer, navigate to Business Component.
  4. Query for TNT SHM Function.
  5. From the Siebel Tools menu, choose Tools, Business Component, and then the Field menu item.
  6. Query for Is Do Not Move Read Only.
  7. Change the value for the Calculated Value field to Y.
    The default value for this field is N.
    Depending on the value you set for the Is Do Not Move Read Only field in Siebel Tools, selecting the Do Not Move Flag check box in Siebel Hospitality results in the behaviors described in About the Do Not Move Flag Configuration Values.
  8. Compile your changes and replace the Siebel Repository File (.srf).
  9. Restart the Siebel Hospitality application.
