Creating Pricing Intervals for Property-Specific Products
You can make products available for sale during specified times, and prevent products from being sold during other times, by creating pricing intervals.
This task is a step in Process of Performing Ongoing Menus and Packages Administration.
To create a pricing interval for a property-specific product
  1. Navigate to the Property Administration screen, then the Properties view.
  2. Identify the property for which you want to create a new pricing interval, and drill down on the Name field of the property.
  3. Depending on the type of product (for which you want to create a new pricing interval), perform one of the actions outlined in the following table.
    For this product type: Action:
    Event order item
    Click Event Order/Menu Items
    Menu item
    Menu
    Click Menus
    Package
    Click Packages
  4. Select the product for which to create a new pricing interval.
  5. Click the Price subview tab.
  6. Select the price list item for which to create a new price interval, and click New Pricing Interval.
    Siebel Hospitality creates a duplicate of the selected record, with all fields filled from the original record except for List Price, Start Date, and End Date.
  7. In the List Price field, enter a price to be effective during the new time interval.
  8. Enter dates in the Start Date and End Date fields.
    Note the following characteristics of the resulting records:
    • The Default value of the Start Date of the new price interval record is the date and time when that record was created.
    • Siebel Hospitality does not allow price records with overlapping time intervals. Make sure the time interval covered by the Start Date and End Date you specify does not overlap the time interval covered by the Start Date and End Date of any other price records.
    • If the previous price record does not have an End Date, when you save the new price interval record, the Start Date of the new price interval record becomes the End Date of the previous price record.
Note: To remove a product from sale for a specific time interval, create pricing interval records for a product that leave that time interval uncovered. For example, to remove a product from sale from January 11, 2010 through February 11, 2010, and then put it on sale again, enter a value of 1/11/2010 12:00:00 AM as the End Date of one pricing interval record and a value of 2/12/2010 12:00:00 AM as the Start Date of the next pricing interval record.
