Creating a Product Catalog
To create a product catalog, follow this procedure.
This task is a step in Process of Adding Catalog Visibility to Hospitality Products.
Navigate to the Administration - Catalog screen, then the Catalog Administration view.
In the Catalog Administration list, create a new record and complete the fields.
Some of the fields are described in the following table.
Field Comments Name
The name of the catalog.
Description
A description of the catalog.
Effective Start Date
The date when the catalog becomes in effect.
Effective End Date
The date when the catalog is no longer in effect.
Private
Select to make the catalog visible only to users belonging to the access groups associated with the catalog. If the catalog is private, all the categories of the catalog are also private.
Active
When selected, indicates that the category is active.
Sequence
The sequence of this catalog in the list displayed to users.
