Disable Hierarchy: TNT SHM Order Entry
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change.
| Disable Hierarchy: TNT SHM Order Entry | Description |
Value |
Y |
Parent Object Type |
TNT SHM Function business component |
Usage |
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change. |
