Editable for TimeScale
This user property is used to specify whether or not the bookings are editable in each time scale.
Editable for TimeScale | Description |
Value |
1;N;2;N;4;Y;8;Y;16;Y;32;N;64;N;128;N;256;N |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC business component TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC business component |
Usage |
This user property is used to specify whether or not the bookings are editable in each time scale. |
