Example of Product Consumption Forecasting
This topic gives one example of product consumption forecasting. You might use this feature differently, depending on your business model.
A customer requests coffee for an upcoming event at which 100 attendees are expected. You know from experience that approximately four out of five attendees drink an average of two cups of coffee at such an event. The price of coffee is 10.00 per gallon. From this information, the consumption quantity of the product can be forecast for this event. The amount of revenue expected from this product can also be estimated for this event.
Create a product representing the coffee in Siebel Hospitality, as shown in the procedure that follows.
To forecast product consumption for an event
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, create a new product record.
  3. In the new record, complete the fields with the values shown in the following table.
    Field Value Comments
    Forecast Qty
    Selected
    Product consumption forecasting is enabled.
    UoM
    Gallon
    None
    Consumption UoM
    Cup
    None
    UoM Conversion Factor
    20
    Each coffee-sized cup holds approximately 6 ounces.
    Consumption Factor
    2
    Attendees who consume coffee are expected to consume two cups each, on average.
    % Participation
    0.8
    80 percent of attendees are expected to drink coffee.
    The forecasting calculations and results for the event are shown in the following table.
    Forecast Calculation Result
    Number of attendees consuming the product
    100 multiplied by 0.8
    80
    Number of cups consumed
    80 multiplied by 2
    160
    Number of gallons consumed
    160 divided by 20
    8
    Revenue
    8 multiplied by 10.00
    80.00
