Named Method 1
Use this user property to set the Per Person Allocation field to an empty string when the UpdateItemsPPA custom method is called.
Property | Description/Value |
Value |
"UpdateItemsPPA", "SET", "Per Person Allocation", """" |
Parent Object Type |
TNT Package Item business component |
Usage |
For a package item, the Per Person Allocation field must be empty if the parent package is of the Package Item Price type. If the parent package type is modified to Package Item Price, the UpdateItemsPPA custom methÂod is called by the UpdatePPA method from the TNT Product - ISS Admin parent business component. |
