Pivot 2 Group Field
This user property is used to specify a data business component field, the value of which is used to group the data in the applet.
| Pivot 2 Group Field | Description |
Value |
Room Name |
Parent Object Type |
TNT SHM SR Inventory Dync |
Usage |
This user property is used to specify a data business component field, the value of which is used to group the data in the applet. |
