Pivot Static Field 3
This user property specifies the fields in the pivot business component that are mapped with applet list columns.
| Pivot Static Field 3 | Description |
Value |
Group field |
Parent Object Type |
TNT SHM SR Type Dync - Group By Type |
Usage |
This user property specifies the fields in the pivot business component that are mapped with applet list columns. |
