Retain Unreserve Popup Default
If the timing for a primary booking is changed, then this user property is used to move the booking to the new time.
Retain Unreserve Popup Default | Description |
Value |
Unreserve |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet |
Usage |
If the timing for a primary booking is changed, then the primary booking is moved to the new time. If a backup space is booked, then this popup provides the option either to retain the backup booking or Unreserve it. |
