Shift SubOpportunities
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. The default value is Y.
Shift SubOpportunities Description
Value
Y or N
Parent Object Type
Opportunity business component
Usage
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y.
