Transient Suite Field
This user property is used to disable the right-click context menu if the Type value of a space is Suite.
Transient Suite Field | Description |
Value |
Is Transient Suite |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary |
Usage |
This user property is used to disable the right-click context menu if the Type value of a space is Suite. |
