Using Function Space Diary Controls in Siebel Open UI
The Function Space Diary control view in Siebel Hospitality leverages Siebel Open UI technologies to deliver a UI control for visually representing bookings that can be used by hospitality organizations to manage function space availability. The following table shows the Function Space Diary controls in Siebel Open UI.
Function Space Diary Control | Usage |
Menu button |
You can use the menu button to invoke additional commands, such as:
Go To Date |
You can use the Go To Date feature, by clicking the date hyperlink and entering a date in the past or future and have the scheduler display the bookings for the date range based on the selected time scale. Based on the selected time scale, you can navigate to the day, week, month, or year using the (forward and back) arrows. When using the arrows, the relative horizontal and vertical scroll bar positions and the selected record stay the same. |
Go To Search Field |
You can use the Go To search field to type in the name of a function space and navigate directly to a function space in the diary. As you type in the name of a function space, you will see all available options in a picklist where you can choose the value you are searching for. Once you select a value, that Function Space displays and the row is highlighted. |
Choose Time Scale buttons |
You can use the Time Scale buttons to select the time scale you want to see in the Function Space diary. Options include:
Display Group Availability on Time Scale |
You can see the group availability on the third axis of the time scale. This axis will display for each day, the Total Group Availability/Group Authorized or just Total Group Available if space is limited and both will not fit. You can also drilldown on the group available, which takes you to the Total Group Availability view. |
Function Space Filter Panel |
These are the different settings controlled by a sliding panel. You can set different booking display options and filters from the function space filter panel. The first half of this pane contains display options that control how things are seen in the utility pane of the diary, such as, booking types, labels, colors and patterns. The second half of this panel contains the filter options that filter out the function spaces depending on criteria applied to the filter. You can also use the function space type drop-down menu to select the function space type you want to see in the diary. |
Color Code Legend |
The color code legend explains color coding of function bookings in the Function Space Diary. The color code legend color information is set in the Function Space Administration screen. Color Code Legend displays the color codes depending on the value selected in the Display By drop-down control under the filter panel. |
