X-Axis Drill Down Enable
This user property is used to specify whether or not to set the field value of Drilldown Name.
X-Axis Drill Down Enable Description
Value
Y
Parent Object Type
TNT SHM Gantt AX Date Time Interval PopUp VBC business component
Usage
This user property specifies whether or not to set the field value of Drilldown Name.
