Y-Axis Drill Down Enable
This user property is used to enable or disable drill-down on Y-axis specific spaces.
Y-Axis Drill Down Enable Description
Value
N
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet
Usage
If the value of this user property is N, then drill-down on Y-axis specific spaces is disabled.
