DB2 Authorizations Required
The following table lists the authorizations that are necessary to implement Siebel CRM on DB2 for z/OS.
Task Authorization Required Task Command Example
Alter a buffer pool.
SYSADM, SYSCTRL, SYSOPR
ALTER BUFFERPOOL
(BP32K1) VPSIZE(4000);
Grant use of a buffer pool.
SYSADM, SYSCTRL
GRANT USE OF BUFFERPOOL BP32K1 TO PUBLIC;
Grant CREATEIN for triggers.
SYSADM, SYSCTRL
GRANT CREATEIN ON SCHEMA SIEBTO;
Create a storage group.
SYSADM, SYSCTRL, CREATESG
CREATE STOGROUP SIEBEL VOLUMES('*') VCAT SIEBEL;
Grant use of a storage group.
SYSADM, SYSCTRL
GRANT USE OF STOGROUP SIEBEL TO PUBLIC;
Grant CREATEDBA and DBADM authority.
SYSADM, SYSCTRL
GRANT CREATEDBA TO SIEBTO;
Create a database.
SYSADM, SYSCTRL, CREATEDBA, CREATEDBC
SET CURRENT SQLID='SIEBTO'; CREATE DATABASE SIDB0001 CCSID ASCII BUFFERPOOL BP1;
Alter a table space.
DBADM, SYSADM, SYSCTRL
ALTER TABLESPACE D0010002.H0677000 BUFFERPOOL BP16K0;
Create a table space.
SYSADM, SYSCTRL, DBADM, DBCTRL, DBMAINT, CREATETS
SET CURRENT SQLID='SIEBTO'; CREATE TABLESPACE H1004000 IN SIDB1004 USING STOGROUP SIEBEL PRIQTY 720 SECQTY 720 BUFFERPOOL BP32K1 SEGSIZE 64 COMPRESS YES LOCKSIZE PAGE;
Modify DB2 Connect package (if package already exists).
DBADM, SYSADM, BIND privilege on the package, ALTERIN privilege on the schema
BIND
c:\sqllib\bnd\@ddcsmvs.lst COLLECTION SIEBEL BLOCKING ALL DYNAMICRULES BIND OWNER SIEBTO QUALIFIER SIEBTO SQLERROR CONTINUE
Add DB2 Connect package (if a package does not already exist).
DBADM, SYSADM, BINDADD privilege, and
IMPLICIT_SCHEMA authority on the database if the schema name does not exist
CREATIN privilege on the schema if the schema name of the package exists
BIND
Alter a table.
ALTER TABLE SIEBTO.S_CONTACT
ALTER COLUMN COMMENTS SET DATA TYPE VARCHAR (100);
Create a table.
SYSADM, SYSCTRL, DBADM, DBCTRL, DBMAINT, CREATETAB
SET CURRENT SQLID='SIEBTO'; CREATE TABLE S_SSA_ID,(…)IN SIDB1932.H1932000;
Alter an index.
ALTER INDEX SIEBTO.S_CONTACT_U1 BUFFERPOOL BP30;
Create an index.
SET CURRENT SQLID='SIEBTO';CREATE UNIQUE INDEX S_SSA_ID_P1 ON S_SSA_ID(ROW_ID)USING STOGROUP SIEBEL PRIQTY 720 SECQTY 720 DEFINE NO CLOSE YES PCTFREE 17 BUFFERPOOL BP2;
Grant CREATE or PACKADM for stored procedures.
SYSADM, SYSCTRL
GRANT CREATE ON COLLECTION SIEBINST TO SIEBDBA;
Grant BINDADD.
SYSADM, SYSCTRL
GRANT BINDADD TO SIEBDBA;
Grant SELECT on catalog tables.
SYSADM, SYSCTRL
GRANT SELECT ON SYSIBM.SYSTABLES TO SIEBTO;
Create User-Defined Functions
SYSADM, DBADM
CREATE FUNCTION SIEBEL.NEXTSEQ (INTEGER) RETURNS SYSIBM.INTEGER SPECIFIC SIEBEL.NEXTSEQ EXTERNAL NAME 'NEXTSEQ' LANGUAGE C PARAMETER STYLE DB2SQL NOT DETERMINISTIC FENCED RETURNS NULL ON NULL INPUT NO SQL NO EXTERNAL ACTION SCRATCHPAD 100 NO FINAL CALL DISALLOW PARALLEL NO DBINFO WLM ENVIRONMENT DB27WLM STAY RESIDENT NO PROGRAM TYPE SUB SECURITY DB2 INHERIT SPECIAL REGISTERS
