Enabling Connection Concentration
The following procedure describes how to enable connection concentration.
To enable Connection Concentration
Set the value of the maximum number of client connections so that MAX_CONNECTIONS is greater than MAX_COORDAGENTS (MAX_CONNECTIONS equals MAX_COORDAGENTS plus 1).
Setting MAX_CONNECTIONS to equal MAX_COORDAGENTS plus1 enables the Connection Concentration dynamic rebalancing capabilities and still allows the transaction pooling to be handled by Siebel pooling.
Note: If you enable Connection Concentration, you must first set the value for the maximum number of agents (MAXAGENTS) parameter; this value determines the value of other parameters. Set the value of the MAXAGENTS parameter as appropriate for your site; this value varies according to the memory available and the number of server connections expected.
