Naming Conventions for Partitioning Triggers
Partitioning Trigger names comprise eight characters (for example, PTH0401) that consist of three elements in the following order:
The leading two letters must be
PT,
to designate that this is a partitioning trigger.The third letter (
H, V,
orS
) designates the product group or component that the trigger belongs to.H
represents Horizontal (also known as Core)V
represents Vertical (also known as Siebel Industry Applications or SIA).S
represents partitioning triggers used for Assignment Manager or other components.
The ending four-digit number uniquely identifies the trigger based on the table number, for example, 0401.
The trigger name is normally related to a corresponding table space name; for example, the trigger name PTH0401 relates to the table space name H0401000.
