Configuring Product Catalog and Category Hierarchies
This topic details the tasks required to configure product catalogs and category hierarchies performed by application administrators. Oracle Pharma Sales Analytics allows users to use a number of prebuilt alternate product hierarchies to analyze and roll up sales and Rx data. These prebuilt hierarchies are as follows:
Manufacturer Product Category
Application Form Product Category
ATC (Anatomical Therapeutic Class) Product Category
User Code (USC) Product Category
Chemical Product Category
The following table shows the Standard Product Hierarchy along with the prebuilt alternative product hierarchies.
Standard Product Hierarchy Manufacturer Product Hierarchy Application Form Product Category ATC Product Category User Code Product Category Chemical Product Category Market
Manufacturer
Application Form I
ATC I
USC I
Family
Submarket
Product
Application Form II
ATC II
USC II
Subfamily
Product
Product
Application Form III
ATC III
USC III
Subfamily
Form/Strength
Product
Application Form IV
ATC IV
USC IV
Subfamily
The Oracle Pharma Sales Analytics ETL uses data stored in the standard Siebel Pharma Product Catalog and Category application screens to create these alternate hierarchies.
To configure product catalog and product hierarchies
Navigate to the Administration - Catalog screen, then the Catalogs view.
In the Catalogs list, create a new record and complete the necessary fields.
Field Comments Name
The name of the alternate Product hierarchy, for example, R-Respiratory for an ATC hierarchy for Asthma products.
Description
A general description of the catalog.
Effective Start Date
Current date.
Private
The product catalog is only used by the Oracle Pharma Sales Analytics ETL. Select this field to prevent the catalog from being visible to other users within the Siebel Pharma Application.
Drill down on the Catalog.
In the Category list, create a new record for the highest (first) level of the hierarchy and complete the necessary fields.
Some fields are described in the following table.
Field Comments Name
Name of the hierarchy level (for example, R3-Bronchodilators and Anti-asthma Preparations for the highest level in an ATC hierarchy for Asthma products).
Display Name
Display name of the hierarchy level (for example, R3-Bronchodilators and Anti-asthma Preparations for the highest level in an ATC hierarchy for Asthma products).
Current date.
Usage
From the Pick Category Usage Type dialog box, select one of the following usage types to set the type of alternate Product Hierarchy, and then click OK:
ATC
- Application Form
- Manufacturer
- USC
- Chemical
Private
The Product Catalog is only used by the Oracle Pharma Sales Analytics ETL Check this flag to prevent the Catalog from being visible to other users within the Siebel Pharma Application.
For each lower level in the hierarchy, create a new record in the Category list, and repeat Step 4.
Set the relationships between the levels by using the Demote level button.
For the lowest level in the hierarchy only, click the Products link under the Categories tab.
Create a new record in the Product list, and select the appropriate Product record, which is the Form/Strength level Product in the standard Product hierarchy.
This action allows Oracle Pharma Sales Analytics to link the alternate product hierarchy to the standard product hierarchy.
