Pharma GA Call Products Detailed User Properties
The following table describes the user properties that apply to the class CSSBCProductDetailed.
| User Property Name | User Property Value | Description |
Max Auto Generated Priority |
Number A numeric value. Example: 3 |
Tells the business component the maximum number to go up to when auto-generating priorities for the products detailed. |
Template Fields |
Field1,field2,… No start or end comma or spaces between values. Example: Name,Priority,Product Issue |
Tells the business component what fields to copy from the Smart Call template if a Smart Call is chosen. |
