Setting Up Codes for Corrective and Preventive Actions
The administrator defines the codes that are used to categorize corrective and preventive actions and their root causes.
This task is a step in Process of Managing Corrective and Preventive Actions.
To set up codes for corrective and preventive actions
See Setting Up Codes.
Note: Typically, you create codes of type Corrective Action for
use with CAPA records. However, all types of codes can be associated
with CAPA records.
