Voiding a Product Issue in Siebel Medical
You can void a product issue that has been accepted by the safety system. The AE Case ID field must have been populated by the safety system before you can void the product issue.
To void a product issue in Siebel Medical
Navigate to the Product Issues Screen, then the Product Issue List.
In the Product Issue List, select the product issue record that you want to void.
In the Reportable field, select Void.
Click Send to Safety.
A nullification message is sent to the safety system.
