Enabling System Data Expressions for Required Columns
Several of the Campaign Contact columns required for the campaign load format must be populated with values that are determined by the list generation process at run time. To accomplish this, you set up the Campaign Contact columns to use system data expressions. The following procedure describes this task.
To enable system data expressions for required columns
  1. Click the properties button on the Campaign Contact column.
  2. In the dialog box, first click the Custom Headings check box.
    This makes sure the table and column name are not changed when you modify the formula in the next step.
  3. Clear the current formula from the Column Formula box.
  4. Place your cursor in the Column Formula box, then click the Available System Data link.
  5. Select the appropriate system data expression from the values in the following table.
    Column Corresponding System Data Expression
    Campaign Id
    Campaign Id
    Load Number
    Load Number
    Scalability Batch Number
    Email Batch Number
    Segment Id
    Segment Id
    Token Number
    Token Number
    Treatment Id
    Treatment Id
    The expression is added to the formula. For example, the Campaign ID column would show the following formula:
    @{campaignID}{0}
    Note: If you get an error message in the Formula dialog box, then ignore the error.
  6. Click OK.
