Encrypting Trackable URLs and Response Forms for Email Marketing
As of Siebel CRM 21.5 Update, Siebel eMarketing allows administrators to encrypt trackable URLs and response forms (Subscribe and Unsubscribe forms).
There are two scenarios for this feature:
URLs in emails. URLs that are sent as a part of emails are encrypted by Email Sending Daemon (ESD) and will be decrypted by Click Through Daemon (CTD) when the URL is clicked. If you install Siebel EMS 21.5 or later, then URLs sent in the email are encrypted and decrypted.
URLs in Siebel eMarketing offers. URLs that are seen on the eMarketing Offers screen are encrypted by Siebel CRM and decrypted by CTD when the URL is clicked. For the URLs in Siebel eMarketing to be encrypted and decrypted, both Siebel EMS and Siebel CRM must be updated to 21.5 or later, and the Siebel Repository must be updated.
The behavior of this feature depends on the version of the installed software and the setting of the user property Encryption. To enable this feature for Siebel eMarketing, set this user property on the Web Offer business component to Y. By default, the value is set to N. When the value is N, the behavior is the same as it is in releases prior to Siebel CRM 21.5 Update.
The following table describes different behaviors for the encryption feature, with different versions of Siebel EMS and Siebel CRM (Siebel eMarketing application).
Installed Software | Encryption User Property | Feature Available in Siebel EMS | Feature Available in Siebel eMarketing |
Siebel EMS 21.5 or later Siebel CRM 21.5 or later |
Y |
Available. The encryption feature is enabled for Siebel EMS. |
Available. The encryption feature is enabled for Siebel eMarketing URLs. |
N |
Not available. Siebel eMarketing URLs work without encryption. |
Prior to Siebel EMS 21.5 Siebel CRM 21.5 or later |
Y |
Not available. |
Not available. |
N |
Not available. |
Siebel EMS 21.5 or later Prior to Siebel CRM 21.5 |
Property not available |
Prior to Siebel EMS 21.5 Prior to Siebel CRM 21.5 |
Not available. |
Not available. |
