Associate Method for a Business Component
The Associate method creates a new many-to-many relationship for the parent object through an association business component. This method does not return any information. For more information, see GetAssocBusComp Method for a Business Component.
Format
BusComp.Associate(whereIndicator)
The following table describes the arguments for the Associate method.
Argument Description
whereIndicator
You must use one of the following predefined constants:
  • NewBefore
  • NewAfter
For more information, see Use Constants to Standardize Code.
Usage
To set field values on a child record that is associated with a parent record, use the context of the multivalue group business component.
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
Examples
The following VB example updates the Opportunity Assignment Type field. The parent business component can be any business component that includes the Sales Rep multivalue group:
Dim oParentBC as BusComp
Dim oMvgBC as BusComp
Dim oAssocBC as BusComp
Set oParentBC = me.BusComp
Set oMvgBC = OpBC.GetMVGBusComp("Sales Rep")
Set oAssocBC = oMvgBC.GetAssocBusComp
With oAssocBC
   .SetSearchSpec "Id", newPosId
   .ExecuteQuery
   .Associate NewAfter
End With
oMvgBC.SetFieldValue "Opportunity Assignment Type", "NewType"
oMvgBC.WriteRecord
Set oAssocBC = Nothing
Set oMvgBC = Nothing
Set oParentBC = Nothing
The following Siebel eScript example finds a contact when the Last Name is Abanilla, and then adds a new organization named CKS Software to the Organization multivalue group:
var ok = 0;
var ContactBO= TheApplication().GetBusObject("Contact");
var ContactBC = ContactBO.GetBusComp("Contact");
with (ContactBC)
   ClearToQuery();
   SetViewMode(AllView);
   // Searches by Last Name
   SetSearchSpec ("Last Name", "Abanilla");
   ExecuteQuery(ForwardOnly);
   if (FirstRecord())
      // Instantiates Organization MVG
      var oMvgBC = GetMVGBusComp("Organization");
      var oAssocBC = oMvgBC.GetAssocBusComp();
      oAssocBC.ClearToQuery();
      oAssocBC.SetSearchSpec("Name", "CKS Software");
      oAssocBC.ExecuteQuery ();
      // Checks if the Organization was found
      if  (oAssocBC.FirstRecord())
         // Organization was found
         try
            oAssocBC.Associate(NewAfter);
            ok = 1;
         catch (e)
            ok = 0;
            TheApplication().RaiseErrorText("Error Associating new Organization");
      } // if oAssocBC.FirstRecord
   } // if FirstRecord
   oAssocBC = null;
   oMvgBC = null;
} // With ContactBC
ContactBC = null;
ContactBO = null;
Related Topics
For more information, see the following topics:
